1 members (Hotrod Lincoln),
130
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2016 Posts: 7 New Guy | | New Guy Joined: Mar 2016 Posts: 7 | I saw a car modification show where the took a 1950's long wheel base f6 truck and removed the rivets holding the rear springs and axle on and slid the entire assembly forward. I understand the chevy have a taper on the frame at the rear but what is stopping one from doing the same thing. What would be the issues that may come up if you do this? | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | it will turn a lot tighter, it may scuff your front tires more while turning and wear them out a bit quicker, depends on how short you go! I had a 57 chev shorty wagon, (was 4 door, cut back doors out and welded back together) it was fun to drive and turned on a dime! | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | I saw a car modification show where the took a 1950's long wheel base f6 truck and removed the rivets holding the rear springs and axle on and slid the entire assembly forward. I understand the chevy have a taper on the frame at the rear but what is stopping one from doing the same thing. What would be the issues that may come up if you do this? I believe others have made SWB trucks out of LWD trucks as you mentioned. Take some measurements to see what may work. If it fits your needs better, go for it. Of course you would have to source a new driveshaft. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | I believe most trucks shops would cut the mid section out and weld/plate it back together leaving the tapered/thin frame in tact. If you slide the axle forward on the frame rails you will be raising the rear of the truck up (higher tailgate to ground) which will also change the front end alignment. Mike B  | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Another factor is the crossmembers at the spring hangers, they may not be the same as the ones further up. It'd be smart to again incorporate crossmembers directly at the spring hangers.
That sliding up trick works on some trucks with identical crossmembers and parallel frame rails, same height. Like Mike points out, not as good an idea when the frame has taper to it. | | | | | Joined: Mar 2016 Posts: 170 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 170 | And here I am thinking I might need to add some extra length to my frame. I wish we could trade problems! | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Adding to wheelbase is no different than shortening it. Only difference is that you have to make two splices on each side instead of one. Too bad that you are not closer, I have several 4' sections on my scrap iron trailer. | | | | | Joined: Apr 2015 Posts: 113 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 113 | I would like to shorten mine so that a 12' flatbed would look right. However, I need about 3' of the tapered section of the frame behind the rear axle first. American LaFrance chopped it when they made it into a fire truck. Once I have that section back to spec I can decide how much to cut out of the middle. Btw, does anyone have one of the cross members from the middle section they dont need from a taskforce 2 ton?
1959 Chevy 8500 - Spartan 80 366 BBC
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Gene, I sent yopu a PM... Mike B  | | |
