0 members (),
88
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#11573 10/01/2003 4:32 AM | Joined: Aug 2001 Posts: 44 New Guy | | New Guy Joined: Aug 2001 Posts: 44 | I lost the dipstick on the 261 that I have. Can anyone tell me the correct length and where the markings are? Will the 216, 235 and 261 interchange? I would also like to know alternate places where the line for the oil pressure gauge can be hooked up to. Original hook up was on the large oil line fittings, but these had to be replaced due to addition of fenton headers. The engine is out of a 1959 2 ton truck and has full pressure oiling.
41 Chev 2dr coupe 51 3100 w/a 261 11 Camaro RS ragtop
#11574 10/01/2003 4:46 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | When I finished up my 261, I didn't have a dip stick either. I went to the wrecking yard and grabbed a couple of dip sticks, but didn't actually like the longer look. I finally took the one out of a 216 I had and used it. I filled the engine with 5 quarts of oil and set the dip stick at the right height to show it full, then made a tube that I tapped into the hole in the block which I made to be the right length. I suppose there are other ways, but that worked for me, especially since I wanted that older "short dip stick tube" look. As far as the oil gauge line, I hooked the gauge up at the regular spot, but used an "L" fitting to turn it toward the back of the block. The line hugs the block above the pan rail and goes toward the back and actually goes around the corner, almost, and up , etc.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#11575 10/01/2003 5:37 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I had to loose the original fitting on mine because it didn't fit my 1/2" NPT hoses, so I drilled and tapped the top of my oil filter housing for an oil pressure gauge fitting. 1/8" NPT, I think. I found a nice thick spot on the outlet side of the can and the threads hold just fine. I have the original '62 filter mounted to the front of the manifold to clear my steering box.
