5 members (TexasJim50, carbking, baldeagle, Hotrod Lincoln, 1 invisible), 87 guests, and 3 robots.
Topics128,018
Posts1,055,340
Members48,419
I recieved my cowl repair panels from Chevy Duty and am ready to get to work. I got the full outside piece that goes all the way to the soldered joint, and my question is-How do you go about removing the solder, do I just take a torch to it? Will that affect the base metal? I don't want to goof anything up. I'm sure I'll have questions about filler material later but I'll aross that bridge when I get there. Thanks.
I melted mine out with a propane torch. You shouldn't have to get it so hot as to warp steel.
Thanks Chuck. Your site is the one I go to for inspiration and how to stuff. It's been a big help. I'm using you idea for reusing the original column with the MII steering also.
