4 members (Hotrod Lincoln, jmoore, NorCal52Suburban, Donf), 183 guests, and 0 robots.
Topics128,105
Posts1,056,208
Members48,436
I purchased inner fenders from a vendor at Hershey last year. When I got ready to install they ended up being short of the fire wall. On an old cab I see that there is a special mount on the driver side to connect the inner fender to the firewall. Is this bracket available for both sides? Should I just build a mount? Anyone have an idea of what it looks like?
Thanks Steve
Steve,
That bracket/mount is only needed on the driver's side inner fender.
That mount is also needed as a hanger for the parking brake assembly.
The passenger side inner fender attaches to/through the floor/toe-board.
Did you buy 1954/55 inner fenders, or 47-53 inner fenders (I think they might be different?)?
They may be correct. Sometimes they get bent out of shape.
Carl
Seems like the fenders look all wrong until everything starts getting pulled into place. That may be what is going on.
I thought my fenders were all wrong until they were mounted on inners and pulled up against hood....hey they fit
imagine that
(the originals had been welded to cowl at some point)
just-a-hacker
'49 3100 before '99
