6 members (frogfarmer, Gray_Ghost, dunfire, Otto Skorzeny, jay d, 50Chevy3100), 81 guests, and 3 robots.
Topics128,056
Posts1,055,804
I've just had my radiator rebuilt and am freshening up the whole radiator support area (1947 AD 216) I have done a lot of searching on the site but am uncertain about the orientation of the bolts that attach the radiator support to the cross member. I have read and seen that they either go down (i.e. head up) or upside down (i.e. head at the bottom. Is there a right way or does it matter? I believe the bolts are 2 inch carriage bolts. (I don't trust some of the things the previous owner(s) have put on the truck.) Any help greatly appreciated. Thanks.
It's a small world, but I wouldn't want to paint it.
Rusty,
Here are some rough illustrations of the from motor mount for a 216/235/261:
Master Parts Catalog
Shop Manual
Two carriage-stle bolts are pushed down through the mounting plate on the front of the block.
Here are instructions.
Here is a post with photos/explanation.
Here is another thread/discussion with a good photo-album by Denny.
Radiator
...link...
Thanks, DADS50
That is a different mount from mine.
I do not know which year used which mount.
Rule of thumb: If you put the bolt up from the bottom and the nut falls off, the bolt drops out and everything falls apart.
If the bolt goes in from the top and the nut falls off the bolt stays in place. Everything is loose but doesn't fall apart.
The rule of thumb I use is: bolt down, bolt head in direction of rotation, bolt head forward in direction of driving. This is unless the only way to insert bolt head is in the opposite direction.
1959 3100 Apache Fleetside
The center mount support has no nuts, it uses a threaded plate
The bolt can only go up from the bottom.
The support on my 50 1/2 ton has two mounting points
The bolt can come from the top and is held in place with nuts.
DADS50,
You are correct, 1947-48 mounts were different from 49-55st. Can you find an illustration for the earlier radiator mount?
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0102.htm
Maybe someone will post links to photos (or, if you have already posted some, would you post the links again?).
The FAM is for 54/55st.
