3 members (DoubleB, Chip O, JW51),
173
Mod | | | Forums66 Topics128,077 Posts1,056,016 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2016 Posts: 40 | I was wondering if anybody uses newer style 6 lug chevy wheels on their bolt. I searched this question but was unable to find an answer. I found some aluminum wheels off of an 03 suburban and am courius if they would fit. Any information would be useful.
Larry
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | After '88, GM went to a different offset/backspace on their 6 lug trucks, similar to what is found on FWD cars. Wheels for the later trucks will not fit on the pre '87 trucks without rubbing or using an adapter spacer to make them fit.
Bill Burmeister | | | | | Joined: Jan 2016 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2016 Posts: 40 | Ok, thanks for the quick reply.
Larry
| | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 | Larry, I've purchased wheels from trailer supply shops. Chevies of the 40"s has a better supply/design it that's what your after
Julian Carter
1970 Triumph GT6 1967 Triumph TR4A 1952 Chevy 3600 1948 MG-TC
| | | | | Joined: Jan 2011 Posts: 188 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 188 | I put trailer rims on my 52 3/4 ton. So far, so good. Had to make sure that the center hole was the correct size as well though. | | |
