3 members (Phak1, TGP, 1 invisible),
107
Mod | | | Forums66 Topics128,260 Posts1,058,322 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | The water pump with two 'heater' ports is made so that each port just shares the flow. The bottom thermostat housing is the same way sharing the flow with the top thermostat housing. It is customarily connected:
1: Upper T-stat housing to upper waterpump connection #1 2: Lower T-stat housing to heater 3: Heater to waterpump connection #2
I think that is right. Others will say if it's wrong. The Heater Valve you refer to is for closing off the flow/heat during the summer months. It is really a duplicate circuit with the true bypass thermostat housings. You can run two heaters if you choose, or you can run two bypasses. | | | | | Joined: Jul 2010 Posts: 592 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 592 | The way Deve describes the installation is correct based on pictures that I have seen from another website. I copied the pictures and posted them earlier in this thread if you want to see the connections.
Matt | | | | | Joined: Jun 2015 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2015 Posts: 59 | Isn't the lower t stat housing just going to continually by-pass hot coolant directly back into the water pump ,wouldn't this cause an overheating situation.
1962 GMC 920 step side 261 4 spd
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | No because the thermostat opens before then. Once the thermostat opens, the entire system won't see more than 200 degrees or so depending on the rating of the thermostat plus about 10-20 degrees in soak temperature. Soak being after you turn the engine off, temperature rises a bit before it goes down.
So you say your Canadian GMC 920 (3/4 ton) came stock with a 261? Are you sure? I know they put the 261 in Canadian Pontiac cars, but always thought GMC had their own stream of engines. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Canadian GMCs used Chevrolet engines - up to big trucks (in GMC terms, Chevrolet did not sell big trucks). Canadian GMC big trucks used what we (USAers) think of as GMC engines.
As you know (but, other may not): Canadian-car 261s came with hydraulic lifters - all USA 261s came from the factory with mechanical lifters. I assume the 58-63 Canadian GMC truck 261s came with mechanical lifters (at least the 1954 Canadian truck 261 has mechanical lifters).
| | | | | Joined: Jul 2010 Posts: 592 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 592 | GMC Kid, the concern that you mention above about the bypass always sending coolant to the water pump and bypassing the radiator whether the thermostat is open or not is correct from what I can tell with the NAPA thermostat. The one that Tim showed closes off the bypass, the NAPA one does not.
As Deve points out, it might not matter. It just doesn't make sense to me to send any coolant from a hot engine directly back to the engine without going through the radiator first.
If I could fine a copy of Tim's thermostat, I would use it on my 261. I really like the design of how the bypass works with Tim's thermostat. Without it, I will use a 235 thermostat and housing. I'm not comfortable circulating some hot coolant back to a hot engine by skipping the radiator which the NAPA thermostat would do.
Matt | | | | | Joined: Mar 2010 Posts: 10,335 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,335 | It just doesn't make sense to me to send any coolant from a hot engine directly back to the engine without going through the radiator first.
Matt When I look at the picture of the 261 with the bypass hose going from the water pump to the top side of the thermostat, I don't see it the same way as you do. What I see is that there is water circulating around the closed thermostat via the bypass hose from the water pump, sending water to the radiator via the upper radiator hose. When the thermostat is closed, it cannot send any water back into the engine via the bypass hose. It all would go to the radiator upper hose. Carl
| | | | | Joined: Jun 2015 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2015 Posts: 59 | The Canadian GMCs came stock with 261s, the engine in my truck is a numbers matching truck and engine,it is a solid lifter engine. So if you look at the picture the upper thermo housing has a hose that goes to the water pump ,the flow goes from the housing to the pump , the lower thermo housing goes through the heater back to the water pump.Would this be correct? If so would the heater circuit always be acting like a by-pass no matter what position the thermostat was in? I have been a Diesel engine mechanic for 25 years the engines I have worked on all had by-pass circuits on them ,but the thermostats were double acting,as they opened to rad they simultaneously closed off the by-pass until it was full open to rad and the by-pass was completely closed off. If the seal blocking off the by-pass leaked the engines were prone to overheat.
| | | | | Joined: Jul 2010 Posts: 592 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 592 | GMC Kid, the installation is as you describe. The heater circuit only acts as a bypass if the heater temperature control is moved toward hot. If set to cold, the valve that opens the coolant flow to the heater core will be closed, so coolant will not flow through the loop.
The way you describe the double acting thermostats you are familiar with work the way Tim's does by closing off the bypass when the thermostat opens. The NAPA one does not.
Matt | | | | | Joined: Mar 2004 Posts: 6,242 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,242 | When I look at the picture of the 261 with the bypass hose going from the water pump to the top side of the thermostat, I don't see it the same way as you do. What I see is that there is water circulating around the closed thermostat via the bypass hose from the water pump, sending water to the radiator via the upper radiator hose. When the thermostat is closed, it cannot send any water back into the engine via the bypass hose. It all would go to the radiator upper hose. Carl The Bypass T-stat is very tall and it only closes off the actual radiator hose outlet in the upper housing. The coolant in the lower part of the upper housing is on the high pressure side of the pump. If the radiator outlet is closed the coolant bypasses back to the low presure side of the pump. I only find evidence the "16 hole - open bypass" T-stat was used in 1962 (261) and again in 1964 (292 & 348). Mike B  | | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | I've been following this discussion with interest. If I could find a bypass thermostat housing and a proper bypass thermostat, I'd install it. Apparently, the NAPA number doesn't actually bypass. Did I read this right?
I also have worked with heavy truck engines and realize the importance of the bypass system. It's common on many gas and diesel engines. BMW even used such a system on cars, as did Mercedes diesels.
Here's how it looks on the road. I have been running a 235 in a pickup that's worked really hard pulling a camper out West and I've been concerned about hot spots. I had the head off for no-lead seats a few years ago and noticed scuffing on #5 cylinder that indicates it's run hot. I believe that #5 is a hot spot and that's why they put the temp. sensor at #5 on the head. hot spotting is not a problem in winter, of course because the heater valve is open. But in summer it's closed. Running on a mountain highway in summer, when you come to the bottom of a long downhill the temp gauge will read south of 160, starting up the other side the engine is a full throttle with the therostat closed and the internal temperature comes up very quickly. Often, mine hits 230 by the top of the next hill. Then, going over the top the engine cools very quickly until the thermostat has a chance to close (2-ton radiator). So with a properly designed bypass system the temperature swings would be reduced. And bet of all the hot spotting would be much reduced. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Jul 2010 Posts: 592 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 592 | Tommy, you are correct about the NAPA thermostat. It properly bypasses with the thermostat closed but does not shut off the bypass when the thermostat opens.
I live in Arizona. I wish I could install the bypass system for all the reasons that you discuss. I drive the mountains in the desert heat and have added A/C, so I have the same concerns as you.
Matt
| | | | | Joined: Feb 2004 Posts: 29,941 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,941 | Anybody got a bypass housing that could be used as a pattern for a CNC mill program? My son-in-law could reverse-engineer one and write the program for whittling out copies from a block of aluminum. He's a CNC mill programmer for Remington in Huntsville Alabama. Jerry
| | | | | Joined: Jul 2010 Posts: 592 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 592 | I stumbled across this diagram that shows how a bypass thermostat works, so I thought that I would share.
https://www.google.com/imgres?imgurl=http://www.agcoauto.com/content/images/cooling/engine_thermostat_flow_open_closed.jpg&imgrefurl=http://www.agcoauto.com/content/news/p2_articleid/191&h=361&w=550&tbnid=R5Dbs0qfsRtmpM:&tbnh=120&tbnw=184&docid=SyjT6_2rLUdJLM&usg=__cACZnxdDZv-8WKEbEd_Zw7ntBug=&sa=X&ved=0ahUKEwjyipzy-PrLAhUI7SYKHb-4DuEQ9QEIIDAA
Matt
| | | | | Joined: Feb 2004 Posts: 29,941 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,941 | That long URL you posted sure messes with the margins on the page! Good diagram of a bypass system, though. Recycling a large volume of coolant back to the water pump inlet keeps hot spots from developing around the siamesed cylinders on the 261, especially with a heavy load onboard. That's why the system was used primarily on the heavy-duty rigs. Jerry
| | | | | Joined: Jul 2010 Posts: 592 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 592 | Click on the attached for the next chapter in this discussion on an easy way to make a bypass system out of a stock 216/235 thermostat housing. I am adding this here to link the discussions as an aid to anyone doing a search on the subject in the future. https://www.stovebolt.com/ubbthread...ing_a_216/235_thermosta.html#Post1163318Matt | | | | | Joined: Sep 2014 Posts: 385 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 385 | So leaving your heater in the hot position when first starting your engine does the exact same thing then right? | | | | | Joined: Sep 2014 Posts: 385 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 385 | the three 261 blocks i have right in front of me have nothing that resembles a bypass in the thermostat housing. | | | | | Joined: Sep 2014 Posts: 385 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 385 | Or instead of doing all this why not just install a nice clean looking spacer like Tom Langdon makes for the water heated intake and flip it or add a second port to the other side to allow for more flow. The spacer as it is already allows circulation within the block as the lines are connected to both the pump and the thermostat housing. I already have the spacer installed on my 235 and its a nice made unit. Here is a link for some other install but its the same thing. Spacer PIc | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Or, just drill a hole in the thermostat "plate" and be done with it. | | | | | Joined: Sep 2014 Posts: 385 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 385 | or that....use about a 1/8" hole? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Jul 2010 Posts: 592 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 592 | Having the heater on hot when starting the engine provides a bypass but will not turn off by itself.
The spacer will not work because it does not have a shut off. If plumbed as suggested, the bypass circuit will be open all of the time.
The 1/8" hole in the thermostat flange will allow trapped air to escape when filling but will not provide enough flow to create an effective bypass circuit. Plus it undermines the integrity of the thermostat (not much) because it always allows coolant to flow past the thermostat, open or closed. If releasing trapped air is a feature wanted in a thermostat, buying one with a jiggle pin is a better alternative.
Matt | | | | | Joined: Sep 2014 Posts: 385 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 385 | Whats wrong with a small bypass pipe possibly 1/4" in size always being open? Mine has been running for 3 seasons on it now. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Yes, about the hole serving as an "air bleeder".
The bottom line is that GM did not use a bypass on these engines, except on some of the heaviest trucks. There is nothing wrong about using/wanting a bypass, but it is not necessary on a light truck that experiences normal driving conditions. | | | | | Joined: Mar 2004 Posts: 6,242 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,242 | Wolf, The heater is actually nothing more than a small radiator, so by opening flow to it during engine warm-up is counter productive, it's cooling the engine coolant making it take longer to get up to operating temperature. Your spacer by-pass doesn't close off when the T-stat opens to the radiator...allowing a small amount of coolant to return to the block without being cooled by the radiator. Mike B  | | | | | Joined: Jun 2015 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2015 Posts: 59 | My 1962 3/4 ton gmc came with this by-pass , I just recently got the truck on the road by-pass system seems to work temp sits at 185 f I used the the 3 piece Napa 180 f thermostat .It all seems to be working the way it should.
