1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | I have the new electrical box from American Auto wire
Where have bolter's been mounting those ? | | | | | Joined: Aug 2011 Posts: 226 'Bolter | | 'Bolter Joined: Aug 2011 Posts: 226 | Are you talking about the fuse block? Pictures would help. | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | yes, it looks like it could mount anywhere | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | This is on my '40 so don't know if it is helpful. I added some pictures to my fuse panel album showing a bracket I made up. It uses the bolts that hold the dash brace going down at the steering column. The fuse panel is meant to bolt on to whatever so I welded a couple of nuts to my bracket. I wanted it up out of sight. I didn't feel there was enough room on the kick panel either. Fuse panel pics
40 Chevy 1/2 ton
| | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | What year truck is it going in? Mike B  | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | What year truck is it going in? Mike B  1949 3100 | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | Since American Autowire was prepared, all the instructions were on box and mounting hardware.
All mounted and now to start connecting things | | |
