1 members (carbking),
142
Mod | | | Forums66 Topics128,266 Posts1,058,386 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2014 Posts: 307 'Bolter | | 'Bolter Joined: Aug 2014 Posts: 307 | Is it possible to reverse or reset the milage on the original odometer? Starting to rehab mine on my 53 1/2 ton Thanks ,Scott | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Yes, it can be taken apart and reset to zero. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Keep the wheels in order, dont mix them up.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Tip #2- If you plan to renumber them make a scribe mark in the side of the wheel between the 1 and the 0 before you clean the wheel surface. The existing numbers will disappear when you clean them. You must get the new numbers in the correct place for it to work right. | | | | | Joined: Sep 2008 Posts: 57 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 57 | Scott, If you don't want to mess around with decals for the odometer, Jim Carter sells a reproduction odometer. I bought one from him on eBay. Here is the link to the part in his catalogue. http://www.oldchevytrucks.com/cart/product.asp?prodid=SP180&i=9935|||||
1966 Chevrolet Caprice 2 Door Hardtop (396 Big Block) 1951 GMC 9434 5 Window (waiting on a 292 transplant) | | | | | Joined: Aug 2014 Posts: 307 'Bolter | | 'Bolter Joined: Aug 2014 Posts: 307 | Once again the Stovebolt forum comes through! Thanks, so much for the continued support and advice ! As suggested above, think I will purchase a new wheel from Jim Carter. Scott | | |
