1 members (carbking), 142 guests, and 3 robots.
Topics128,266
Posts1,058,386
Members48,485
#1155798 03/19/2016 10:50 PM
Is it possible to reverse or reset the milage on the original odometer? Starting to rehab mine on my 53 1/2 ton
Thanks ,Scott
scottss60 #1155806 03/20/2016 12:10 AM
Yes, it can be taken apart and reset to zero.
scottss60 #1155809 03/20/2016 12:33 AM
Keep the wheels in order, dont mix them up.
scottss60 #1155823 03/20/2016 3:30 AM
Tip #2- If you plan to renumber them make a scribe mark in the side of the wheel between the 1 and the 0 before you clean the wheel surface. The existing numbers will disappear when you clean them. You must get the new numbers in the correct place for it to work right.
scottss60 #1155846 03/20/2016 12:47 PM
5 Online: Content
Scott,
If you don't want to mess around with decals for the odometer, Jim Carter sells a reproduction odometer. I bought one from him on eBay. Here is the link to the part in his catalogue.
http://www.oldchevytrucks.com/cart/product.asp?prodid=SP180&i=9935|||||
1966 Chevrolet Caprice 2 Door Hardtop (396 Big Block)
1951 GMC 9434 5 Window (waiting on a 292 transplant)
scottss60 #1155897 03/20/2016 6:49 PM
Once again the Stovebolt forum comes through! Thanks, so much for the continued support and advice ! As suggested above, think I will purchase a new wheel from Jim Carter. Scott
