6 members (Greg '46, Hotrod Lincoln, Phak1, Otto Skorzeny, 2 invisible), 234 guests, and 2 robots.
Topics128,080
Posts1,056,063
Members48,433
#1153770 03/06/2016 8:05 PM
Hi all. I am planning to paint stock rims in two tones: orange and silver / grey hammertone. One color will go in the center and the other on the outer ring.
Do you think the rims would look better with orange in the middle and hammertone on the outer ring, or hammertone in the middle and orange on the the outer ring?
Would I be crazy to paint the rims on one side of the truck reverse of the other side to see which one looks best?
The truck is a satin black '52 GMC.
Stove #1153809 03/07/2016 12:44 AM
Check out the 67-72 Chevy Trucks forum on this link for the Photoshop where you can post the colors and rim and someone will likely produce a photoshop image.
http://67-72chevytrucks.com/vboard/forumdisplay.php?f=33
Copy and post the images here if you get them too.
~~ Darcy
1959 GMC 9310 Canadian- built Shortbox Fleetside Deluxe
FootStomper
In the Project Journals Forum
Stove #1155463 03/17/2016 3:21 PM
I decided to paint the rims orange in the middle. The color scheme looks good to me but my painting sucks - I had a lot of difficulty with "orange peel".
A two-tone scheme was used instead of one because I felt that fully orange wheels would be too much for 16" rims.
Pics:
Rim - before
Rim - after
Stove #1155474 03/17/2016 5:32 PM
Big Bolt Forum Moderator
looking good! Are you using spray paint? If so, soak the cans in a bucket of HOT water.... I drop them in till the water starts to cool down, then empty and refill bucket with fresh hot water, and then pull a can out and start painting. That helps the paint lay down smoother and dry a bit faster.
Mike
Stove #1155485 03/17/2016 7:18 PM
Yes, spray paint. Thanks, great tip!
I'll get it right next time.
Stove #1155501 03/17/2016 9:43 PM
I usually put mine near an incandescent light bulb to warm it up. Not sure how much heat they can take before bursting but a few minutes, shake it, few more and it seems just fine.
Dennis
40 Chevy 1/2 ton
Stove #1155514 03/17/2016 11:20 PM
I set mine on the floor next to the deep freezer vent. Nice little warm air breeze there.
I have left a can in the direct sun too long one day and it came out of the can like wasp and hornet spray!
Stove #1155567 03/18/2016 4:48 AM
How old is the Orange paint? Did you shake the crap out of it before spraying? Did you try a different nozzle? All these things can affect outcome.
Also, the painted rim appears to be a 6 clip...which is narrower than the 3 clip... Is that what I'm seeing in the pictures?
~~ Darcy
FootStomper
Stove #1155602 03/18/2016 3:55 PM
Hi Darcy, good tips.
The problem I think is that it is cold here (maybe 2 to 10 degrees C) and my garage is not heated.
Yeah, these are the 6 clip wheels. I don't really have a good set of hubcaps, and that's a big reason for painting the rims...
Stove #1155693 03/19/2016 12:56 AM
You shouldn't even try to paint steel when its temperature is below 70 degrees, imho.
Carl
