3 members (baldeagle, NorCal52Suburban, DaveV), 124 guests, and 1 robot.
Topics128,037
Posts1,055,470
Members48,424
Good Afternoon, I need to replace the door lock cylinders or the whole latch button I don't care. The locks on both doors won't unlock or turn. Does anyone know how to remove the cylinders or door buttons?
Is button the right word?
Ultimately I would like to key the ignition and door the same. My truck is almost all original. Bottom line I need to get the doors to open from the outside without having to reach through the vent window. Thanks for the help.
1959 Apache.
Big Bolt Forum Moderator
once you take the handle off, you can remove the "button" and/or lock cylinder. American classic has the complete lock kit for 95$, all keyed alike. (assuming for the 59 Apache in your signature line). Part # lok-21 http://www.americanclassic.com/asp/...;iyear=1955&ytype=to&exyear=1959
Mike
Thank you 69 Cuda. Once I open up the inside of the door I assume it is easy to get the door handles off ?
I appreciate the help and the recommendation on the parts shop. Obviously I didn't do all of the work on the truck or I would know more. I bought it 9 years ago and last year I threw in the towel and turned the truck and about a dozen boxes of misc. parts over to a pro who did a great job getting finished. The truck looks great except that the chrome on the new door handle buttons rusted off in less than a year and then they stopped working altogether. Thanks again.
1959 Apache.
