| | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2015 Posts: 89 Shop Shark | | Shop Shark Joined: Sep 2015 Posts: 89 | I noticed quite a bit of wobble on my balancer while running my engine. I hammered it back on with a rubber dead blow mallet after changing timing cover seals, etc. it was already pretty beat up looking before hand around the hole for the crank but i hadn't noticed this much wobble.. I was considering just buying a new one since it would be so easy to install at this point- are there different size balancers for this engine? I found this one on Summit for pretty cheap - but some I see are hundreds of dollars, what am I missing here?? Dorman Harmonic Balancers 594-014 http://www.summitracing.com/parts/rnb-594-014/overview/
1946 Chevrolet 2-ton
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I don't think you can seat a balancer with a rubber hammer. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The list of applications for that Dorman balancer does not seem to include a 235. | | | | | Joined: Sep 2015 Posts: 89 Shop Shark | | Shop Shark Joined: Sep 2015 Posts: 89 | well I meant plastic sorry, it was a plastic 12lb dead blow hammer. I tried a sledge with a wooden block as well after it was in the truck and I noticed the wobble, I'm certain its seated properly - belts line up etc...
| | | | | Joined: Sep 2015 Posts: 89 Shop Shark | | Shop Shark Joined: Sep 2015 Posts: 89 | Are these a special kind of balancer that isn't made aftermarket?
can they be found in the $50-$75 range? All i can seem to bring up is harmonic balancer sleeves on any of the Auto parts websites
| | | | | Joined: Sep 2015 Posts: 89 Shop Shark | | Shop Shark Joined: Sep 2015 Posts: 89 | why are these units so expensive vs the 230 balancer i listed above for $55? just supply and demand or is there something different about them?
I have an old balancer off a 261, would that work? (if its any good that is)
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I think the 261 balancer will work. I can relate though. I was looking for a dual pulley balancer awhile back and the cheapest I could find was about $450. Even if you cobble something together and have it machined, the cost is up there. | | | | | Joined: Sep 2015 Posts: 89 Shop Shark | | Shop Shark Joined: Sep 2015 Posts: 89 | ok thanks everyone, i'll pull the balancer again and try my luck with the 261 balancer and see what happens!
It was good to hear the engine running in the truck again! even though i found more problems!
| | | | | Joined: Sep 2015 Posts: 89 Shop Shark | | Shop Shark Joined: Sep 2015 Posts: 89 | How much wobble would be acceptable? I would say its 1/4 inch at idle and smooths out as engine speed increases to an almost unnoticeable amount.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I'd worry about having that much wobble. | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | The inner part that attaches to the crankshaft is bonded to the outer part with the pulley. With some kind of rubber(elastomer?) the density of that rubber stuff matters. It does the "Damping" work. When that bond fails...there can be hell to pay. Wobbles equal a fail. Common reason for the bond to fail is the use of the wrong puller when removing and striking the outer part when installing. The 2 parts are big chunks of Iron. Not likely to be damaged by much. The bond however can be broken. I use the 2 threaded holes to pull and an old socket in the center with a block of wood(a chunk of 2x4 works) and a BFH(large hammer) to reinstall. If it is a slip fit on the crankshaft, then drill and tap for a retaining bolt. Can the damper from a 216 be used? Pulley width might be the issue?
Steve H
| | | | | Joined: Feb 2008 Posts: 108 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 108 | I found a harmonic balancer for my 1958 235 from Langdon's Stovebolt 6. Tom Langdon, 586-739-9601. | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | Don't apply any force to the outer ring. If it wobbles, or you can move the outer ring with your hand don't use it again. Do not “just to run it for a while like this”. It may not last a while. A failed bonding rubber also sends the outer ring through your radiator, hood, fender etc.
