BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
| | Forums66 Topics126,776 Posts1,039,271 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | Gas Pumper Joined: Dec 2000 Posts: 3,399 | | | | | Joined: Dec 2015 Posts: 43 Wrench Fetcher | Wrench Fetcher Joined: Dec 2015 Posts: 43 | I removed the center head bolt and after a few seconds of engine idling, oil started oozing up into the head. I will cut a slot in the threads of the head bolt and see what happens. Does anyone know if a 61 235 engine should have one of those drilled head bolts? | | | | Joined: Jan 2001 Posts: 5,320 'Bolter | 'Bolter Joined: Jan 2001 Posts: 5,320 |
See the USA in your vintage Chevrolet! My Blog | | | | Joined: Dec 2015 Posts: 43 Wrench Fetcher | Wrench Fetcher Joined: Dec 2015 Posts: 43 | Excellent blog post. Thanks! | | |
