| | | Forums66 Topics128,080 Posts1,055,951 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 152 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 152 | I need 14x2.5 shoes and wheel cydrs, who is a good source for these? | | | | | Joined: Aug 2012 Posts: 177 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 177 | Wheel cylinders can be found at NAPA and Chevs of the 40's.
I have been looking for shoes with no luck. I am going to get them re-lined at my local brake place. | | | | | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | Previous Post I can't recommend the Dorman wheel cylinders after trying to install them. The mounting bolt holes are misplaced and the bolts can't be tightened up against the backing plate. The other stuff fit perfectly.
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
| | | | | Joined: Jul 2012 Posts: 83 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 83 | Napa brake shoes UP-299R are 14x2.5 bendix style brake shoes. They fit perfect on my '53 except I had to drill the hole for the park brake arm mounting bolt.
1953 1 ton panel
| | | | | Joined: Jan 2011 Posts: 152 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 152 | Thanks for your help. The Napa part no# for the rear wheel cyd is #18010 its 1"1/4 bore. Parts are coming in a few days. | | | | | Joined: Jan 2011 Posts: 152 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 152 | Napa can get your shoes Redlegs48 if they are the same as mine the part # is up-299r. Thanx PootersPanel | | | | | Joined: Aug 2013 Posts: 116 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 116 | This was very helpful! Thanks for the item numbers. I called my local Napa and they had the cylinders and shoes. Saved me from pulling some hair from my head!!
1942 BK 1/2 Ton Pickup 1954 3800 1 Ton Pickup
| | | | | Joined: Aug 2013 Posts: 116 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 116 | I placed my order from NAPA. Shoes look to be fine, cylinders don't fit. The screws just don't line up. So I found AUTOZONE has similar ones, DURALAST item number 33048 and ordered them from there. Fingers crossed those will work. Otherwise I suppose I can just rebuild them.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Did you check Rockauto.com?
| | | | | Joined: Aug 2013 Posts: 116 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 116 | Yes, I bought all my items for the front from Rockauto but they don't have the items for the rear.
| | | | | Joined: Aug 2013 Posts: 116 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 116 | The fronts were DURALAST and fit just fine so I hope the backs are the same.
