3 members (baldeagle, Jon G, Peggy M), 241 guests, and 5 robots.
Topics128,106
Posts1,056,214
Members48,436
'52 3600 with replacement 2 circuit master cylinder. I've read about needing to bleed the master cylinder.
Not sure if it pertains but will someone explain how to bleed the master cylinder.
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
To bench bleed a MC I clamp the MC in a vice, Connect a short brake line to each circuit (steel or rubber), bend the lines around to put the open end back into the reservoir, fill the reservoirs with brake fluid to a level above the open end of the lines you just installed, insert a screw driver into the MC push rod opening and slowly start pushing the plunger in and out, when you stop seeing bubbles coming out the brake lines on the push stroke you're done. Remove the lines, install the MC cover/cap and install the MC in the vehicle.
Hope this helps,
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Great Thanks Mike
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
