7 members (Otto Skorzeny, Southerntruck, Guitplayer, Hotrod Lincoln, 52Carl, qside, 1 invisible), 160 guests, and 3 robots.
Topics128,087
Posts1,056,115
Members48,435
#1152581 02/29/2016 1:59 AM
Have a 261 with a 4.3 dia water pump pulley. I also have 2 dampers, one with a 6" dia pulley and the other with a 6.75" pulley. What would be the fan rpm for each pulley at engine speed of 2000 rpm. What is a "typical" fan speed?
ryanz #1152641 02/29/2016 1:50 PM
Around 2800 vs 3100 RPM
IDK what typical speed/ratio should be. The only steady state RPM would be at highway cruise speeds.
SimS
ryanz #1152726 02/29/2016 10:41 PM
U
U Offline
DcCrpm= DfFrpm
(Diameter of the crankshaft pulley)(crankshaft pulley/engine RPM) = (Diameter of the fan pulley)(fan RPM)
Both sides of the equation must balance out.
Brad
Wrench Fetcher, PhD
ryanz #1152738 02/29/2016 11:39 PM
Give me ambiguity
or give me something else
ryanz #1152760 03/01/2016 1:02 AM
I could not go larger than 6" on the damper or the pulley would rub on the motor mount. That's on a 1951 with a 235. Maybe I have a problem some other place.
CASO #1152764 03/01/2016 1:34 AM
U
U Offline
Originally Posted by CASO
... but talk forum members into hammering out sheet metal into fender patches as opposed to buying replacements? Touché. grin
Brad
Wrench Fetcher, PhD
ryanz #1152772 03/01/2016 2:11 AM
Far more important: that's also the water pump RPM. Slow it down too much = always runs hot.
Fan speed only matters in traffic, above 35 mph you can remove the fan entirely.
The best fan design: the largest diameter turning at the slowest speed, with a shroud.
ryanz #1152795 03/01/2016 4:49 AM
.... but I never said that!!!
I said if I made one it would be the greatest patch ever and the five layers of bondo were just for enhanced rust protection... our manufacturers have sold us out but I will makes great panels for everyone!
Wheres that LMC catalog?
Give me ambiguity
ryanz #1152798 03/01/2016 4:54 AM
U
U Offline
LOL!
Brad
Wrench Fetcher, PhD
ryanz #1152823 03/01/2016 1:05 PM
Leo Offline
Moderator
Moderator
Ryan, I don't know my fan speed, but I had that 4.3" water pump pulley too, at first. (261 engine) It was very obviously spinning the fan too fast. I simply slipped a larger pulley, about 6" diameter right over the smaller one, using the 4 small fan bolts to hold it in place. I have been running it for 4 years, no issues.
