0 members (),
79
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 74 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 74 | Lately I have been having trouble shifting while driving my 3 tree 54 1/2 ton. While driving along I'll suddenly have trouble getting the clutch fully engaged in any gear. The gears whine and when clutch is disengaged the truck won't coast as you'd think it should, like it wasn't free. I'd smell transmission fluid while it is in gear and whining. Eventually I can get it working fine in all gears and it will work fine but I never know when it will get stuck again. Does this seem like a linkage adjustment issue? Clutch going out? I appreciate any ideas on what the problem is and how to fix it. Thanks much! Steve | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Steve,
Have you check the gear oil height in the transmission?
Have you checked the clutch adjustment (as per the shop manual)?
| | | | | Joined: Apr 2013 Posts: 74 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 74 | I have not checked the gear oil height. The clutch has no free play at all. My shop manual suggests free pedal travel of 3/4 to 1". Could this be the issue? | | | | | Joined: Aug 2013 Posts: 116 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 116 | Does oil leak from the flywheel dust cover by chance? I believe my rear main seal is bad. I think I may be having a similar issue and was just assuming that oil was gooing up the clutch. When I put my '54 in gear, say 3rd, I don't feel the power I should. Almost as if the truck is at a slowing speed. If that makes sense. I can't figure it out.
1942 BK 1/2 Ton Pickup 1954 3800 1 Ton Pickup
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I have not checked the gear oil height. The clutch has no free play at all. My shop manual suggests free pedal travel of 3/4 to 1". Could this be the issue? Yes | | | | | Joined: Apr 2013 Posts: 74 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 74 | I adjusted the clutch linkage to give me 1" play and that seems to have solved the problem. Thanks to all for the input. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Good work, StephenB  | | |
