3 members (Bill Hanlon, 66flea, 55shaker), 90 guests, and 1 robot.
Topics128,052
Posts1,055,725
#1151585 02/22/2016 11:53 PM
Does using a 12V coil on a 6V system have any advantages or disadvantages other than a strong blue spark versus a weak orange spark? Thanks!
6XChevy #1151586 02/23/2016 12:01 AM
This subject has been beaten to death for years- - - -pretty soon you'll hear some self-styled "engineer" come along and tell you there's no such thing as a 12 volt coil! Just run what the factory installed and forget about all the drama.
6XChevy #1151608 02/23/2016 2:53 AM
Oh, and welcome to Stovebolt, New Guy!
(Sometimes Hotrod's "warm and fuzzy" demeanor is masked by his intensity.)
Carl
6XChevy #1151638 02/23/2016 4:47 AM
Do I need an external resistor when using a 12V battery and 12V coil on the 1960 235 engine in my 1950 3100 with stock 6V system? 52Carl, where in Va. are you? Thanks to all.
6XChevy #1151648 02/23/2016 5:49 AM
Yes. The "12 Volt" Delco coil is actually designed to operate properly at around 9 to 10 Volts DC. If it's run without a resistor the points will have a very short life due to excessive current flow. During a cold start, the battery voltage will drop to around 9.5 volts, so with the proper resistor bypass circuit in place, the coil will still provide a good spark.
BTW, the myth about the "hot blue spark" that everybody considers to be ideal went away in the mid 1960's when Delco started using TV/Radio suppression cable (TVRS) instead of copper-cored spark plug wires. All that metal-core wire does is cause distributor caps and rotors to burn out prematurely.
6XChevy #1151650 02/23/2016 5:55 AM
Just to complicate things, or maybe simplify, there are also 12v coils with an internal resistor.
Dennis
40 Chevy 1/2 ton
6XChevy #1151656 02/23/2016 6:46 AM
Denis,
The benefit to using an external resistor with the bypass circuit wired correctly is that when the starter is engaged the balast resistor is bypassed putting the full battery voltage to the coil for a better start.
If you use an internal resistor coil you loose that feature and the already low voltage while cranking the engine over is made even lower causing hard starts.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
6XChevy #1151687 02/23/2016 3:27 PM
I understand what you are saying Mike. It is no issue on my truck though. It cranks fast and starts right up. Maybe because I have the 6-volt starter pushed at 12 volts?
Dennis
40 Chevy 1/2 ton
6XChevy #1151689 02/23/2016 3:33 PM
Gas Pumper
Gas Pumper
He is asking if the 12 volt coil would benefit him while hes running a 6 volt system. 6 volt systems do not have ballast resistors or bypass circuits. The answer is no, they will run exactly the same. If you are experiencing a weak spark on your 6 volt system, some troubleshooting is in order. All stock ignition systems clear into the 1970's are 6 volt ignition systems.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
6XChevy #1151690 02/23/2016 3:41 PM
Thanks for all the responses. Next question, why did GM go to a 12V coil when all the systems run on 6V?
6XChevy #1151692 02/23/2016 3:44 PM
12 volt coil and 12 volt battery doesn't sound like a stock 6 volt system to me. Does that even work without changing the 6-volt generator to 12 volt?
Dennis
40 Chevy 1/2 ton
6XChevy #1151697 02/23/2016 3:58 PM
Ignore my last question, I figured it out. Thanks again!
6XChevy #1151748 02/23/2016 7:45 PM
Gas Pumper
Gas Pumper
Shoot! wink
Deve
The Think Tank
