4 members (TexasA&M48Truck, UtahYork, stlcardinalsguy, 1 invisible), 50 guests, and 3 robots.
Topics128,026
Posts1,055,404
Members48,422
#1151612 02/23/2016 3:04 AM
Comments follow on my turn signal installation (1951 3600 6 volt). I used a 535 flasher from NAPA (made in China), the flashers were fast, like a bulb was out...not the case though. Also the flasher did not make a perceptible clicking noise even though it is billed as a thermal unit and not one of the newer generation electronic flasher units.
I found a NOS Tung Sol 6V 535 flasher made in the USA on ebay and picked it up for around $15 delivered.
Good news, the flashers now flash at a reasonable rate and its easy to hear the good old fashion Click-a Click-a of old.
So, my advise is to consider something other than the NAPA 535 for your 6 volt flasher needs.
RonR
1970 340 Duster
1964 CJ5
When I was at 6 volts, a new 6-volt flasher went way too fast also. I went to a junkyard and found an old flasher in a junked AD. They gave it to me free and it flashed just right.
In this link you will see the difference and the reason the NAPA flashers work complete different, and not in a good way.
Four pictures, scroll right.
My Blog
