5 members (TUTS 59, 32Fordpuchoptop, panel fan, UtahYork, Otto Skorzeny), 68 guests, and 0 robots.
Topics128,078
Posts1,055,939
Members48,430
#115133 11/22/2002 1:05 AM
I want to replace my incorrect 59 fender spears with the correct 58 fender spears. The problem is the 58 spears will go farther back on the fender than the 59's did, so I am left with a hole. the 59 spear also rubbed a little on the paint (even a little rust) leaving a mark where the front pointed part of the spear went.
So the question is for a non-body / painting guy, is there a cheater way to fill the hole, and loose the arrowpoint mark?
I do have a pint of the correct color paint.
I know I can paint the entire mess, but thought there may be a way to get by for a while and still hold my head up. Thanks for any help you can supply.
56 stepside 3/4 ton longbed
#115134 11/22/2002 10:08 PM
Junior Member
Junior Member
How big is the hole? I assume it is just a hole for a clip? My only thought would be to use automovie masking tape to put as close as you can to the area you want to repair. (to circle or sqaure the area in) then sand or sandblast the rust away, fill in the hole with body filler. (welding would be better)Spray or brush primer on. Sand it, then brush or spray just a bit of your paint on. The masking tape around the area is so when ya work on the area you won't get sanding scratch marks past the small area you want to work on. It will be less obvious. If the colour is non metallic you can colour sand it and buff it out and no one will be the wiser smile If it is a metallic colour you will be left with a circle or square mark around the repair and the paint won't blend right. But if you plan on repainting the whole truck or fenders in the near future i would just touch it up now. Then weld over hole before ya paint the whole panel. Just an idea. Good luck!
*under construction* 1962 Chev truck: Bagged & bodydropped, shaved, custom made clear tailights & roll pan, custom made aluminum parts.
http://www.geocities.com/philswebsite2003/
