4 members (TexasA&M48Truck, Mike B, 1955 1 Series, baldeagle), 121 guests, and 2 robots.
Topics128,026
Posts1,055,409
Members48,422
#1150527 02/16/2016 11:04 PM
I have the sm420 granny gear transmission in my 51 and would like to know if there were different speedo driven gear tooth counts for that transmission. Mine is a 14 count tooth and I saw one for sale on ebay that was a 12 tooth, supposedly for the same transmission.
I am looking to buy one.
Depending on tire size and axle ratios several speedo gear ratios were used on SM420s.
The parts book shows 4 tooth drive and 12 tooth driven for 1948-54 with 4.11 diff.
My Blog
52-53 had 0-90 speedo
Not sure if that will effect your ebay search
Thanks for the info!
I have a 1949 with a 4-speed (SM-420) out of a 1951 3/4 ton and a rear gear with 3:90 ratio. open drive shaft, but I don' see where that matters but I would sure like to know about what I need also. I did not intend to take your post over just seems like a good place to find out what I need. Thanks Steven
1949 Chevy 1/2-Ton ~ Red Truck
More pix on Photobucket
