2 members (Buckeye998, J Lucas),
301
Mod | | | Forums66 Topics128,152 Posts1,057,012 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 127 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 127 | probably been asked many times, but does anyone have a good diagram of a 1946 truck with an alternator? cant believe these companies will sell you a new harness with just a slip of paper with numbers on it. any help would be greatly appreciated. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | There is no simple answer:
- do you have a 1, 2, 3, or 4 wire alternator? - do you have an internal or external voltage regulator? - do you have an ammeter or a voltmeter (and, do you want to use it)?
Your question is asked about once a month, but the answers sometimes become quite long and confusing. | | | | | Joined: Apr 2008 Posts: 127 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 127 | sorry, single wire, internally regulated, using stock ammeter in truck. | | |
