2 members (Uncles51, Shardean), 50 guests, and 4 robots.
Topics128,021
Posts1,055,356
Members48,420
There is alot of GOOD postings for alignmet,I will use them all if need be...Question:should I install new weather-striping on the doors (52) BEFORE aligning?? Anyone have any good "after the fact" advise on gluing the seals on? I can see where it will be a one-shot deal...
I want the dors to fit properly before rubber is installed. The best way it so install the rubber before the jambs are painted, leavig them in there with for a week or so. Then remeove them, paint and reinstall the rubber. When they are new, they can really cause problems. They seem to be a lot begger than the original was, so they need dome time to crush down.
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
Glue the NEW rubber in for a week or so?? Or just put the new rubber in the jams w/o glue?? that would seem to distort the rubber in the wrong places...??
Makes sense to want to squish the new rubber but.... :confused:
Russ,
I aligned my doors before installing the rubber.They were absolutely perfect, then when I added the weatherstripping my door bottoms stuck out about a 1/4"Needless to say I was very unhappy , but I left the doors shut for about a week and they are slowly seating themselves again without adjustment.Personally I think I still would of done it the same way if I did again!!
Good luck to ya.Just my 2cents worth.
Alan
Live every day to the fullest for tommorrow never comes!!!
I'm sorry, I forgot that these trucks HAD to have the rubbers glued in. That trick works well on other cars where you can install and then remove.
1948 Chevy Pickup
