| | | Forums66 Topics128,026 Posts1,055,403 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 36 | I have the sm420 granny gear transmission in my 51 and would like to know if there were different speedo driven gear tooth counts for that transmission. Mine is a 14 count tooth and I saw one for sale on ebay that was a 12 tooth, supposedly for the same transmission. I am looking to buy one.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Depending on tire size and axle ratios several speedo gear ratios were used on SM420s. The parts book shows 4 tooth drive and 12 tooth driven for 1948-54 with 4.11 diff.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | 52-53 had 0-90 speedo
Not sure if that will effect your ebay search | | | | | Joined: Oct 2011 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 36 | | | | | | Joined: Jan 2010 Posts: 378 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 378 | I have a 1949 with a 4-speed (SM-420) out of a 1951 3/4 ton and a rear gear with 3:90 ratio. open drive shaft, but I don' see where that matters but I would sure like to know about what I need also. I did not intend to take your post over just seems like a good place to find out what I need. Thanks Steven | | |
