1 members (Naturalthud), 110 guests, and 3 robots.
Topics128,135
Posts1,056,423
Members48,441
#1150474 02/16/2016 3:52 PM
I have a Rochester carburetor that's rebuilt. I think that it's a 'B'. What is the difference in the B, BC, & BV. The carburetor chart on internet is not much help without a number (which I don't have).
I'm in the same boat. I have what I think is a Rochester B in need of a rebuild. Here's a link to my pictures. Check them out and let me know if yours looks like mine. If they do, we can both (hopefully) get our answer here.
http://s817.photobucket.com/user/bballfreak21/library/
There might be multiple versions of each of those "models"
different types of choke mechanisms
B - manual choke
BC - automatic choke
BV - vacuum break/brake (?) - "vacuum operated diaphragm plunger"
http://carbkitsource.com/carbs/tech/Rochester/B-index.html
http://www.carburetor-parts.com/Rochester-B-BC-BV-Carburetors_c_649.html
http://www.thecarburetorshop.com/RochestermultipleB.htm
big download - 1964 manual that describes the three 1964 models:
http://www.newagemetal.com/pages/ServiceProcedures/B/1964/64ModelBmanual.pdf
Thanks for the info! It seems mine is a "B", we'll wait to hear from larryelvick on what he's got.
My carburetor must be a BC it has a auto choke with a heat tube run down to the exhaust manifold for heat to operate the choke.Thanks again guys for the replies. This won't be the last time I will be needing help.
That is what was/is on my 1954 3100 with Hydra-Matic
