| | | Forums66 Topics128,015 Posts1,055,335 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#11501 03/15/2005 5:10 PM | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | I am in the process of rebuilding a '56 235. I have a 261 solid lifter cam that I'm installing. My question is do I adjust the lifters the standard .006 intake and .013 exhaust, or do I adjust them the heavy duty .010 intake and .020 exhaust? TIA
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
#11502 03/15/2005 7:38 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I'd go with 6 & 13. Better for performance.
Fred 52 3600 69 C-10
#11503 03/15/2005 8:45 PM | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Use the specifications for the engine the cam was designed for. The adjustment spec is also the height of the "clearance ramp" built into the cam. so if you go with a different clearance, the transition from clearance to lift doesn't happen at the right time. That's also the reason not to use hydraulic lifters on a solid lift cam, as it increases the total duration by a bunch. Hydraulic cam clearance ramps are usually only .002" or so, instead of .015" or more. Jerry
#11504 03/16/2005 6:09 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 261 cubic inch
Intake: .006
Exhaust: .018 (up to 1 ton trucks); 020 (over 1 ton trucks) | | |
#11505 03/16/2005 2:29 PM | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | Thanks for the help, fellas!!
