9 members (klhansen, rfs56trk, Bill Hanlon, 1955 1 Series, DHedrick, Otto Skorzeny, 39Master85, greenie-reddy, Peggy M), 136 guests, and 3 robots.
Topics128,087
Posts1,056,399
Members48,442
I'm going to clean and re-pack the front wheel bearings on my '53 Chevy 3100 but am not sure about the rear bearings. The owners manual says "The 1/2 ton semi-floating axle has the wheel bolted directly to the axle flange, the bearing is in the outer end of the axle housing and rides on a special race on the axle shaft just back of the axle flange." Are these axle bearings easily accessible or is this something I should avoid until I have a problem? Are rear axle bearing problems common? Thanks!
~Denny
1953 Chevy 3100
w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter
1998 Chevy Suburban 350 ci awd/4wd
The only thing I would suggest is to pull the rear drums once in a long while to make sure that the axle seals aren't leaking. The bearings don't require maintenance.
1951 1 Ton Completed
Along with following truckernix's suggestion, be sure to regularly check the rear-end lubricant/gear-oil level, and top it up as required.
Will do, guys. Thanks for the advice!
~Denny
1953 Chevy 3100
With the rear tire/rim removed, lift up on the axle shaft flange to feel for any up and down movement. If there is no, or little discernible movement, you are good to go.
Carl
Thanks, Carl. I appreciate the tip.
~Denny
1953 Chevy 3100
