6 members (kades51, frogfarmer, baldeagle, Brian Moore, Hotrod Lincoln, 1 invisible), 28 guests, and 8 robots.
Topics128,020
Posts1,055,345
Members48,419
#11501 03/15/2005 5:10 PM
8
8 Offline
I am in the process of rebuilding a '56 235. I have a 261 solid lifter cam that I'm installing. My question is do I adjust the lifters the standard .006 intake and .013 exhaust, or do I adjust them the heavy duty .010 intake and .020 exhaust? TIA smile
-Tim
'51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
#11502 03/15/2005 7:38 PM
I'd go with 6 & 13. Better for performance.
Fred
52 3600
69 C-10
#11503 03/15/2005 8:45 PM
H Online: Content
Use the specifications for the engine the cam was designed for. The adjustment spec is also the height of the "clearance ramp" built into the cam. so if you go with a different clearance, the transition from clearance to lift doesn't happen at the right time. That's also the reason not to use hydraulic lifters on a solid lift cam, as it increases the total duration by a bunch. Hydraulic cam clearance ramps are usually only .002" or so, instead of .015" or more.
#11504 03/16/2005 6:09 AM
261 cubic inch
Intake: .006
Exhaust: .018 (up to 1 ton trucks); 020 (over 1 ton trucks)
#11505 03/16/2005 2:29 PM
8
8 Offline
Thanks for the help, fellas!!
-Tim
