2 members (NJC, baldeagle),
57
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#11499 03/03/2003 3:33 PM | Joined: Jan 2002 Posts: 175 Member | | Member Joined: Jan 2002 Posts: 175 | Can anyone shed any light on the correct caster angle for a 49 1/2 ton? The manual discusses correcting the caster angle but I can't find where it states what the correct angle should be. My old springs had eight leaves and a short wedge shaped ninth leaf that the through bolt went through also. My new springs have eight leaves as I understand is correct. What degree shim wedge should go under the spring when I install them? Thanks | | |
#11500 03/03/2003 5:08 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | The correct castor is between 2 and 4 degress, with 4 being better for trucks having a higher rear than front. You can buy caster shims/wedges at your local spring or hot rod shop or online from various vendors.More castor increases straighline stability and adding a touch more steering effort.Too little castor may cause a shimmy. Make sure the trucks king pins are in good repair. | | |
