Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (UtahYork, 50Chevy3100), 197 guests, and 4 robots.
Topics128,284
Posts1,058,523
Members48,490
#114979 10/20/2004 7:37 PM
Junior Member
Junior Member
I have a 50 Chevy 3100 in process.
I need to locate the metal "C" shaped channel that the cab windlace is mounted to around the inside of the cab door opening.
Anybody know where I can locate pieces?
I specifically need the front piece running from the floorboard up the front side of the cab opening to the top of the cab opening. The top and back side are intact.
#114980 10/20/2004 8:19 PM
Z
Z Offline
I was never able to find any, I resorted to sheet metal screws with decrative washers in this area to hold the rubber The problem is the channel is pretty well destroyed removing if not already rusted out. Zeke
The Amish Connection
51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
#114981 10/25/2004 3:02 PM
Some of the vendors sell repair pieces that you can spot weld in. Mothertrucker also probably has the real deal in rust free AZ
#114982 11/01/2004 5:11 AM
Hi Jerry, try Tom Myers Truck Parts in Miami Ok.
I was missing a lot of the inside parts for my
46 1/2 ton and Mr Tom came thru with real nice, almost rust free parts. Very reasonably priced.
Phone 918 543-3871 Tell him Ed in New Orleans
told you about him.
Good Luck Ed
#114983 11/07/2004 3:39 AM
Jim Carter used to sell pieces, but I think he stopped. I agree, you probably need to hit one of the used parts vendors. But a lot of the regular vendors sell used parts also. Just have to call around and see if they can help.
