5 members (Gdads51, cmayna, JW51, BC59, Forty9), 108 guests, and 2 robots.
Topics128,092
Posts1,056,457
Members48,443
Stovebolt Photo Moderator
My ODSS brothers, Mike B, Chris and 53-green 1-ton helped me get my 216 started last year. I was never able to seat my intake/exhaust manifolds seated sqaurely against the head. I tried everything - even a different manifold set. Then it hit......I looked closer at the rings that go between the intake and head. They look to be home-made and of different depth. And too deep. I bet they are made from old exhaust pipe stock. I have 2 questions: 1) For test stand purposes can I run the motor without them, 2) are after market replacements available. If not I guess I will grind these down an 1/16" or so to get them to seat without creating a holiday between the manifold and the head. Thanks - Joe PS: Mike B - I had that Zenith carb rebuilt, what a difference !
1947 - 3800 dually known as "Deadwrench"
Link to a few photos
In this world there are givers and takers. The takers eat well, the givers sleep well.
It's a pretty simple task to narrow your home-brewed rings a little, but yes, replacements are available. There's even a set of stepped rings for fitting a 216 manifold to a 235 head, which has different manifold and head hole diameters. I'd use my lathe for fitting purposes, but a vise and a file will also work if you support the rings with a piece of dowel rod or something similar to keep from collapsing it while you file or grind the thickness down a little. Try some of the antique parts vendors who advertise here.
I have decreased the depth of the rings by carefully using a belt sander.
http://www.classicparts.com/1934-53...216-235/productinfo/89-305/#.VrdfYpMrKdE (for 216s and pre-1954 235s)
http://www.classicparts.com/1954-62...Sleeves/productinfo/89-306/#.Vrdf75MrKdE (for 1954-1953 235s/261s)
Larrow & Sons use to make sell those port-size-adapters (but their web catalog is not working). Jim Carter used to sell them, but they do not seem be listed now.
If you find them listed on-line, please post links
You do not need the alignment rings to make a good seal, but is very hard to correctly align the manifolds assembly to the head without the rings.
Patricks has the stepped adapter rings in his catalog.
Crusing in the Passing Lane
I made some for my 302, just get some tubing that is too big, cut a piece out 'til the correct dia., then weld if you wish.
Ed
I see where this is going, I will work with the rings I have by sanding/grinding them until I get a flush fit. Thanks for all the suggestions Bolters.
