Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (78buckshot), 176 guests, and 3 robots.
Topics128,274
Posts1,058,433
Members48,490
#1148267 02/04/2016 5:18 PM
I recently got a '53 GMC 100 running and now need to start addressing the rest of the truck. It needs glass (most of the glass is there, but is more translucent than transparent), wiring, some patch work (cab corners and floor, primarily), and lighting.
Would it be best to do the cab sheet metal work first, then the paint, and finally the glass? I would think this would facilitate prep for painting, but I have never gotten this far into a project and would appreciate any advice.
gusco #1148272 02/04/2016 5:43 PM
sheet metal
paint
glass
electrical/lighting
gusco #1148504 02/05/2016 6:25 PM
Thanks! I ordered the .023 drive rollers and liner for my mig last night (already have tips). I'll practice a bit and then order up the necessary patch panels as $$ allows. Anything else you guys think is necessary or even indispensible for the patch panel work?
gusco #1148591 02/06/2016 3:59 AM
Buzz little spots with plenty of space between to keep heat down to prevent warping. Planish the welds after completing each pass across the panel while they are still hot. This counters the shrinkage of the panels as they cool. If you ever feel like you're making good time on stitching the panels together, you are likely going 3 times too fast.
Carl
gusco #1148723 02/07/2016 1:55 AM
Gotcha! I'll be watching some YouTube videos to try to get a good idea of how to get it done right.
gusco #1148747 02/07/2016 3:24 AM
Check out Robert "MP&C" posts. Some of the best info and tips you'll come across.
You'll find him on several forums if you google.
Copper backing pieces and clamps make things a lot easier.
Give me ambiguity
or give me something else
