| | | Forums66 Topics128,014 Posts1,055,332 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2015 Posts: 285 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 285 | I recently got a '53 GMC 100 running and now need to start addressing the rest of the truck. It needs glass (most of the glass is there, but is more translucent than transparent), wiring, some patch work (cab corners and floor, primarily), and lighting. Would it be best to do the cab sheet metal work first, then the paint, and finally the glass? I would think this would facilitate prep for painting, but I have never gotten this far into a project and would appreciate any advice. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | sheet metal paint glass electrical/lighting | | | | | Joined: Feb 2015 Posts: 285 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 285 | Thanks! I ordered the .023 drive rollers and liner for my mig last night (already have tips). I'll practice a bit and then order up the necessary patch panels as $$ allows. Anything else you guys think is necessary or even indispensible for the patch panel work? | | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | Buzz little spots with plenty of space between to keep heat down to prevent warping. Planish the welds after completing each pass across the panel while they are still hot. This counters the shrinkage of the panels as they cool. If you ever feel like you're making good time on stitching the panels together, you are likely going 3 times too fast. Carl
| | | | | Joined: Feb 2015 Posts: 285 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 285 | Gotcha! I'll be watching some YouTube videos to try to get a good idea of how to get it done right. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Check out Robert "MP&C" posts. Some of the best info and tips you'll come across. You'll find him on several forums if you google.
Copper backing pieces and clamps make things a lot easier.
