| | | Forums66 Topics128,054 Posts1,055,781 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2003 Posts: 4 Junior Member | | Junior Member Joined: Nov 2003 Posts: 4 | Is anyone having problems fitting the after stock cab corners. I have put mine on twice and the door jam doesn't fit right or the back doesnt line up. | | | | | Joined: Nov 2004 Posts: 61 Member | | Member Joined: Nov 2004 Posts: 61 | Just did a set on a 49 chevy ,had no problems!
got a hidaway gas door from Williams and had to disassemble it because the radius was way off! | | | | | Joined: Jun 2004 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 100 | Bodiman, who's repair panel did you use?
Andy
A man is like an old truck... He will rust out before he wears out...
