2 members (Hotrod Lincoln, 1 invisible),
156
Mod | | | Forums66 Topics128,189 Posts1,057,337 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 283 Shop Shark | | Shop Shark Joined: Oct 2008 Posts: 283 | On an advanced design, what is the easiest way to set up the column shifter. On my truck, I was not given the correct rods, that has confused me, also if look on page 12-4 of the shop manual they show only two rods, however if you look on page 7-1 of the factory assembly manual it shows 1 long rod and then two rods for 2nd and 3rd.
Thanks in advance of advice.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Find a neighbor and measure his.
Ed
| | | | | Joined: Jan 2001 Posts: 1,426 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,426 | Ed? You of course meant by 'neighbor' a Stovebolter.
I made my own rods using heim joints and threaded the rods, it's a good 8 hour day to dial it in but it shifts as new. Now if you are going for 1000 pt restoration, you need to find that 'neighbor'.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
