Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Woodcmiami, Peggy M, Southerntruck), 117 guests, and 6 robots.
Topics128,282
Posts1,058,496
Members48,490
#114774 11/14/2003 5:25 PM
if anyone can show me a schematic or picture of how a mechanical window on the drivers side of a 1968 gmc truck works it would be really helpfull. I have to take the mechanis from one door and put them in another so an explanation of how it works would be realy good. Thanx for any help
#114775 11/17/2003 1:47 PM
I
Junior Member
Junior Member
I Offline
The window operation can be hard to explain but.....theres a piece called the regulator...it is like a large pair of sissors...As the sissors open and close the glass goes up or down in the tracts on each end..The trick to removing the parts is to remove the wing window first ..There are screws on the front edge of the door and one bolt on the lower inside that holds the wing assembly and entire front tract...Have the main window rolled all the way UP.!!...KEEP YOUR FINGERS OUTTA THE SISSORS .!!!....After the wing assembly is out remove the main winbow out through the top by tilting forward... smile smile
If all the cylinders ain't in a line it ain't cuttin it..
#114776 11/19/2003 4:45 AM
thanx, ill give it shot
