0 members (),
170
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | does anyone know if there are ANY roller lifters that will slide right into a 305 v6? I think I may have a lifter going bad and wondered if this could be a possible solution. not looking for a racing engine, just a solution to an issue that I have. I will go with flat lifters but just throwing an idea out there.
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | | | | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | If you have lifter wear, there will also be corresponding damage to the cam lobe it's riding on. I don't think there's a suitable roller lifter that will interchange, and there would have to be a fair amount of modification to the block to keep a roller lifter running in line with the cam lobe. Flat lifters are designed to spin in the block- - -rollers have to stay aligned with the lobes. Jerry
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | What makes you think a lifter is going bad? | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | A roller tappet operating on a flat tappet lobe will have profoundly different characteristics - especially much reduced valve-open area, and large changes in tappet acceleration. Don't. | | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | well alright, I really appreciate being able to ask and get a good straight answer on here, thanks guys  Oh, the noise that made me start wondering is a bad exhaust gasket, guess I was jumping the gun a little bit.
