5 members (Tronman, Otto Skorzeny, TUTS 59, Millenimech, 1 invisible), 116 guests, and 3 robots.
Topics128,042
Posts1,055,509
Members48,424
#114731 07/15/2002 5:11 PM
I am replacing the bed wood on my 55-1 daily driver. I am kicking around the idea of using a sheet of marine plywood instead of the individual boards? Any potential problems with this installation?
#114732 07/15/2002 5:20 PM
two problems. The bed is more than 48 inches wide, so you need two pieces. Also, you need to seal the edges of the plywood real well. It will soak up moisture and allow the plywood to delaminate.
54 3100 with 235
62 flatbed dump C60 with 261
#114733 08/11/2002 10:06 AM
I would use a sheet of galvanized or stainless steel.
DUSTY G.
you can do anything you want as long as you have an O [censored] man in case you mess up
