7 members (Otto Skorzeny, J Lucas, klhansen, Tronman, electors, 78buckshot, 1 invisible),
106
Mod | | | Forums66 Topics128,042 Posts1,055,497 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 8 Member | | Member Joined: Mar 2002 Posts: 8 | I am replacing the bed wood on my 55-1 daily driver. I am kicking around the idea of using a sheet of marine plywood instead of the individual boards? Any potential problems with this installation? | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | two problems. The bed is more than 48 inches wide, so you need two pieces. Also, you need to seal the edges of the plywood real well. It will soak up moisture and allow the plywood to delaminate.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Jul 2002 Posts: 46 Member | | Member Joined: Jul 2002 Posts: 46 | I would use a sheet of galvanized or stainless steel.
DUSTY G.
you can do anything you want as long as you have an O [censored] man in case you mess up
