1 members (1 invisible), 368 guests, and 5 robots.
Topics128,162
Posts1,057,043
Members48,463
Just learned the brake drums are different o the 53 /54 half ton . Is the axel the same or not.
Layback
layback
According to Hollander the front axle from '41 to '55 1st are the same.
The 1953 and 1954 1/2 ton truck front axles are the same.
The 1953 and 1954 1/2 ton truck front brake drums are the same.
Guess the guy selling the drums got his year mixed up. The center of the drum at the lug area is raised.
Len
layback
You asked are the axles the same. Had you asked are the drums the same I would have told you drums were the same from '40-50 then changed and were the same from '51-59. Again, Hollander is my reference. Sounds like the seller has the earlier drums.
