2 members (Nick in Manitou, 1 invisible),
350
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 10,305 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,305 | I especially enjoyed Grigg's unbridled scolding of 'Da Boss' about staying away from the not-so-easy outs.  I do, however believe that cletis is losing his sharp edge by allowing this clearly off-topic discussion to remain in this forum.  (Special note regarding the two 'smiley faces') Carl
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Yes it is kind of off topic but there really isn't a proper place to put it. And it is a truck part. So I cut a little slack for the boss. Maybe I'll get a raise. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | The way I figure it, if Grigg can't do it, You are just screwed. John knows this from experience, so that is why the outcome was totally expected.
The other day I was dealing with one of Griggs inventions, and had a SEVERE problem. I wanted to call Grigg, but didn't have his number. (Grigg is happy that I do not have his number, trust me). So it was the 1/2" thick oil adapter bracket that he did for Cosmo. Someone wanted one, so I made one for them. This is where it gets interesting...
While tapping the #7 hole for the 1/4-20 tapped hole, I broke the tap off about half way through the 1/2" and flush with the top, so no way of grabbing it to turn it out. That was about a one hour ordeal I really hope to never repeat!
In a case like that, there is no amount of heat, reverse drill bits, easy outs, nothing I know of that even starts to fix the problem. None of the regular ideas worked. In the end, since it was only tapped half way, a very long very sturdy punch and a very big ball peen hammer were the only hope. My 20 ton shop press just bent my very solid punch, so out of ideas, and a little bit mental by this point, I just beat that sucker out of there! Once I pushed it out the way it came, I had enough threads to feel good about its holding ability.
But MAN!!! What would Grigg have done? He doesn't realize that there are people out there that ask that question. After Grigg, the same question could be asked of Jesus. I think Jesus would have called Grigg! | | | | | Joined: Feb 2010 Posts: 477 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 477 | I can't see the pic of what your dealing with,but the best way is to disassemble it, put it in a mill and get dead centered on the bolt. Then you can drill it out with carbide if necessary. And Heil coil it if the threads are damaged (If your burning up drill bits,sharpen them at the first sign of heat,slow the rpm down and use lots of cutting oil) | | | | | Joined: Aug 2001 Posts: 3,615 Moderator | | Moderator Joined: Aug 2001 Posts: 3,615 | Deve I have done that before with a punch. But the punch will not last long against a broken tap. Save old taps and tool bits, to sharpen up and break the teeth out of the stuck/broken tap. There are even more tricks out there, but once a piece of tool steel is broke off deep, it will take tool steel and patients to get it out. Punches are just surface hardened and after a few wacks, you will be using mild steel.
Don Edit: I forgot to add, Grigg is a very talented metal worker and I have seen his shop. He also makes great homemade ice cream. Black berries are in the freezer and will be ready for the Stovebolt Homecoming.
Don
1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Seems like somewhere I remember a tool for removing broken taps that has steel fingers to insert in the flutes of a tap to remove a broken tap, anyone seen one?
Remember when drilling and tapping, drill the correct size hole and run the tap in with your Bridgeport before moving the table. Use back gear for the tap, of course. If the tap gets tight, it will spin in the chuck before breaking.
I routinely do this and never had a problem, however, on pure Al, unknown at the time, the tap started galling and I shut it down, got some Al alloy instead.
Ed
| | | | | Joined: Aug 2001 Posts: 3,615 Moderator | | Moderator Joined: Aug 2001 Posts: 3,615 | Ed I have tried those finger tap removers. They do not work unless the broken tap is loose in the hole. May even have a set somewhere in an old tool box. http://www.newmantools.com/walton/extrtap.htmDon 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Feb 2010 Posts: 477 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 477 | The only thing that's going to remove a jammed broken piece of high speed steel (a tap) is bolting your part down to a mill and go threw the center of it with carbide tooling. All the other ways are hit and miss, mostly miss! | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | There are always other ways... There is an EDM machine made solely for burning out broken taps. In my experience this is often the best way, least likely to harm the part. It is certainly not the only way. | | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | Has everybody lost sight of the original problem in all this theoretical discussion? The setscrew is at an oddball angle in a difficult location on a big piece of equipment that would be impossible to set up in a mill, an EDM, or any other sophisticated piece of equipment. This one is going to end up as a very tedious operation with hand tools with two possibilities of success- - - -slim and none. I would choose a diamond-dust burr in a variable-speed tool like a Foredom flex-shaft device, the same way I deal with broken-off #6 screws in rifle receivers. Now, to really increase the pucker factor, try removing a broken scope mount screw on a $15,000.00 custom engraved Mauser, made before WW II by a German master gunsmith! Jerry
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The original mission was accomplished. It is time to shut this one down. | | |
