| | | Forums66 Topics128,165 Posts1,057,087 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 219 'Bolter | | 'Bolter Joined: Jan 2007 Posts: 219 | Just learned the brake drums are different o the 53 /54 half ton . Is the axel the same or not. Thanks Layback
layback
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | According to Hollander the front axle from '41 to '55 1st are the same. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The 1953 and 1954 1/2 ton truck front axles are the same.
The 1953 and 1954 1/2 ton truck front brake drums are the same. | | | | | Joined: Jan 2007 Posts: 219 'Bolter | | 'Bolter Joined: Jan 2007 Posts: 219 | Guess the guy selling the drums got his year mixed up. The center of the drum at the lug area is raised. Len
layback
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You asked are the axles the same. Had you asked are the drums the same I would have told you drums were the same from '40-50 then changed and were the same from '51-59. Again, Hollander is my reference. Sounds like the seller has the earlier drums. | | |
