4 members (baldeagle, Otto Skorzeny, tclederman, Rusty Heaps), 58 guests, and 9 robots.
Topics128,020
Posts1,055,345
Members48,419
#1146920 01/28/2016 2:34 PM
Looking to faint info on how far other people have moved radiator forward with out grill mods
29 Ford
http://s1078.photobucket.com/user/c...4-BF50-713F5EDE5632_zps8zoj9vfq.jpg.html
31 Ford
55 panel
95 4 door power stroke
49 chevy 2 ton
47 2 ton grain bed w/ hoist.
Many trucks waiting
Looking to gain info
29 Ford
31 Ford
55 panel
49 chevy 2 ton
Many trucks waiting
back yard wrench turner
I moved mine to the front of the cowl channel without any other mods.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
You might want to indicate the year of truck (original poster, and responders).
"I moved mine to the front of the cowl channel without any other mods."
I thought you had to cut into the upper and lower valances, or whatever they're called, to do that? Interested too. Doing a 250 swap into a 53 3800 soon.
Larry W.
1953 3800 Dually Flatbed
"soon"
Well sooner or later. LOL
Crusing in the Passing Lane
GMC trucks have a slightly longer engine, 228-302, their radiator is moved fwd in the grille support approx. 3", might look at a GMC for ideas. What type and year are you talking about?
Ed
AD type truck(52 1/2 ton) with a 235 I moved to the inside of the radiator support. Trim the bottom corners off the radiator mount and had good spacing from the fan. With a newer I6 I don't know. I did need to trim the top cover where the latch lives to clear the radiator cap. Not much, just a bit to save my thumb when the cap is twisted off. Next time I will convert the water pump. The fan is too low on the radiator. Again with the newer motor I am not sure how far you would need to move.
Steve H
"GMC trucks have a slightly longer engine"
Probably would have remembered that, but didn't see it mentioned. I am going to look at the difference between them for ideas though. I don't mind cutting for room, truck is rough and will stay rough, at least until the wife protests enough. I'm sure the GMC latch panel and the Chevy grille etc. can't be mixed.
Larry W.
"Again with the newer motor I am not sure how far you would need to move."
Another member said all he did was move the rad to the front of the mount. The fan was close but safe and the head was 1/2 off the firewall.
My cab will need lots of sheet metal and as long as there is nothing in the way, I will even entertain a SMALL relief welded into the firewall. Picture a Thunderbird hood scoop....not the chrome part. nono
https://c1.staticflickr.com/5/4154/5006000363_bc177a8847_b.jpg
Not to move the engine back, just for more clearance...I will be using the stock trans with a '54 crossmember and 60's V-8 bellhousing. Truck is a "53.
Larry W.
Here is a link to what I did on my '48 Chev. I haven't finished grafting the GMC with the Chev pan yet, but you get the idea. http://www.canadianrodder.com/forum/showthread.php?t=14736&page=11
Looks good.
Larry W.
Bond Villain
Bond Villain
Check the Tech Tips -- for some engine swaps, all you need to do is switch to a short-shaft water pump (available from most of our vendors) and an adapter (to move the fan up to the correct position for best cooling). There may be no need to move the radiator and cut up those nice, original splash/valance panels.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
I got some measurements looks like I can move. 5 inches out and put fan on outside of radiator move the 7.3 forward and no cutting of the firewall except for small area for down pipe to curve over valve cover and at tat h to turbo . This was great too see. Except now I'm refabing motor mounts. If I could figure out the pic thing I would post. If anyone on her does We Chat there posted on it for my friends out of the country
29 Ford
31 Ford
55 panel
49 chevy 2 ton
Many trucks waiting
