3 members (JW51, UtahYork, Wickedbass), 61 guests, and 2 robots.
Topics128,066
Posts1,055,876
Members48,428
#1145856 01/21/2016 9:43 AM
I am about to run trans cooler lines, can I run solid lines all the way or do I need to have a flex in there some place? Th400 with 350 in a 46. Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
Most factory coolers run solid steel tubing lines, but if you want to add a short piece of flex line between the trans and the body it will avoid getting stress cracks at the flare fittings. Just be sure the flex line is rated for carrying hot oil somewhere in the 250 degree range, as trans fluid can get pretty hot on a hard pull.
if you are going to the frame with the cooler i would put in a rubber line.
There is enough flex in the line, but I always run a short piece of rubber line just to be safe. Anywhere your steel line could rub on something, split a piece of rubber line and wrap your steel line with it, then use a zip tie to keep it there. Or if it's a sheetmetal edge, put the rubber hose over the sheet metal.
My 46 GMC on Photobucket
V
VEW Offline
V Offline
homer52, what size trans cooler are you using, 18"?
I'm needing to put one in my 41 3/4ton, 350/700r4, and don't know how to size one. I will be using it as a "truck"; carrying at least one ton.
~ Victor
1957 3100 - moved on
It's difficult to "over-cool" a working transmission. I use the biggest one that will fit the space I have available. On some really hard-working rigs like a vehicle that will tow a big camping trailer often, I have used an entire air conditioner condenser as a trans cooler, but that's probably a little overkill.
I got a new aluminum rad and it has a trans cooler section in it.
1941 Chevy
The coolers in the rads are fine for street use in cooler climates. For those planning on towing or heavier usage or are in a hot climate, you're better off with an auxiliary cooler.
V
VEW Offline
V Offline
I plan on using my original radiator. So whatever cooler I install will be the only one. Just want to make sure it will be sufficient.
~ Victor
