| | | Forums66 Topics128,181 Posts1,057,185 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | who might look in on the forum. Being able to make or modifying parts while restoring an old truck is a definite asset and that's the driving force behind my gathering and restoring some of these old machine tools. I've been working on putting my old Ladge & Shipley 16" lathe back in service. I've got the change gears, which were missing their pilot bushings all back in place now and have been working on the motor drive. But....I got one more thing that has to be done to the new pilot bushings, that is, I need to get the figure-eight oil grooves in the three new pilot bushings: http://www.pbase.com/dennygraham/image/162399074I read an old thread from another site on grooving machines and read a Popular Mechanics "how to convert an old lathe to be used as a groover", but the only "old" lathe that I've got in the barn that I would be willing to sacrifice is a tiny toy of a lathe, an AA109 that a guy threw out and I dragged home. "Don't throw it away, give it to Graham." I'm sure that even if I went to the trouble of rigging up the crank and linkage that, that toy lathe would never hold up to putting a groove in a cast bushing, besides, it's missing almost all of the change gears, the spindle and the planetary back gear, so it isn't even much of a toy lathe to begin with. So, I'm sure I know the answer already.....but I figure it never hurts to ask....any simple solutions in mind, or how'd you do it? I'd sleep better if I could make a controlled grove in them, but for only three pieces, a Dremel with a burr will probably be the simplest way, after all, it's only a path for oil and who's gonna see it, right...cringe! Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Aug 2001 Posts: 3,616 Moderator | | Moderator Joined: Aug 2001 Posts: 3,616 | Denny I used to make bronze bushings for punch presses we would rebuild. An "H" pattern for the oil/grease grooves. Cut a groove on each end of the bushing, then turn your tool horizontal and brooch between the groove using the carriage by hand. Also make sure to put the chuck in a low gear to prevent any chuck rotation during the brooching. I usually put three or four horizontal groves between the circular grooves.
Hope this makes sense and helps.
Don
1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | External oil groove? Today that would be done on a CNC machine with a rotary fixture also being controlled.
You can do almost as nice a job with your Bridgeport, a ball endmill, and a dividing head. (Or as perfect a job with change gears added in linking table travel and dividing head rotation) Forget about the change gears as you probably don't have them... Back to the basics I'd probably stop short of figuring out the math for table position and angular rotation at regular steps. (Though not confusing if you want to) Instead draw your pattern on there with a sharpie, possibly transferred from a paper template traced from the original. Then manually follow along both rotation and table travel. I'd cut it full depth in one pass so you don't have to trace more than once.
That would be a step between full CNC or fully geared manual setup and hand held dremel.
Grigg | | | | | Joined: Aug 2001 Posts: 3,616 Moderator | | Moderator Joined: Aug 2001 Posts: 3,616 | Thinking back on what Grigg said about external grooves. All the bronze bushings I made had internal oil grooves. Just another thought, can they be modified to take sealed needle bearings?
Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | I think I would have used oilite bronze- - - -no need for a lube groove. Jerry
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Oh Jerry, you're just to practical. Restoration----The original support bushings were cast and space and hold the threading gears in their proper relationship. They were and will continue to be..cast iron. I just need to duplicate the original oil grooves as close as I can, not re engineer the lathe. Besides, the cast iron pilots are already machined and fit up. Straight grooves would be simple to make Don, that's not the problem. There already is one radially close to the flange. I'm looking to make an external figure eight spiral groove that leads in from the counter bore in the casting. All of the old machines used this sort of a groove to pump oil to the whole bearing surface. And again, rollers not needed here, the machine ran for half a century without any noticeable wear and I'd still use the original pilot bushings if I had them, but...they were one of the parts that were missing when I bought the lathe.
Of course a CNC Turning Center would be nice to have Grigg, but....three pieces....you know....doesn't justify my looking for a $60K machine for the shop. Not really gonna go to the trouble of setting up the Bridgeport for three pieces, it's not that critical. I'v about talked myself into just sitting down by hand with the Dremel and cutting them in as close as I can by hand. dg
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I wasn't advocating for the CNC approach.
I was trying to say you could very quickly and easily do a good approximation by hand so to speak with your Bridgeport.
Setup is as easy as plopping a dividing head on the table line it up straight by eye would be close enough. Chuck your part in it and have at it with a ball end mill.
Sorry I was not clear to start with. I thought by briefly outlining how it would be done properly you could see a compromise and a quick and easy way to do it "good enough". Likely faster and more predictable than entirely by hand with the dremel.
Perhaps I misunderstood the question, were you looking for agreement only or asking for new ideas? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Oh I know you weren't suggesting that Grigg. I was just making conversation, I have been known to be a bit of a smart ars at times you know. I carved a few of these out on the Logan 825 10", http://www.pbase.com/dennygraham/image/162311175 and the hand eye coordination on the Bridgeport for the grooves probably wouldn't be much more challenging. Like you suggested, pre-mark the path and just crank left and right, somethin' like patting your head and belly at the same time. Think I might take you up on that suggestion, thanks. And you bet.....one pass only else that groove would look pretty bad. Somethin' like the path of a drunken sailor. dg Denny G
| | | | | Joined: Aug 2001 Posts: 3,616 Moderator | | Moderator Joined: Aug 2001 Posts: 3,616 | Great picture Denny and I can tell the skill put into it. But, and my eyes may be deceiving me, the print shows left handed threads and the part looks like it has right handed threads. As my feeble mind remembers, Bridgeports handles were always right handed threads.
Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Picky, picky, picky! Dint think anyone would notice, least I dint. That's just a quickie working drawing Don, not meant to be followed on a tracer or CNC or with any precision. Those sort of things are more sculpture than anything else. I did take Grigg's suggestion, only problem is I don't have a dividing head, only a spin index and rotary table. Rotary is not suited to this and I'm afraid the spin index is gonna do just that, i.e., spin and snap off the ball end mill. http://www.pbase.com/dennygraham/image/162402641But, it will have to wait till tomorrow cuz it's just to dang cold out there in the barn and me feet and fingers have lost feeling. Besides, it's supper time and I don't want to ruin my supper by screwin' up my part. Thanks Grigg for the idea. dg
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Ive used a super spacer at times for similar jobs where a dividing head was the real answer. Put a long handle on it so you can control it well. On the super spacer I stick the long cross pin part of the chuck wrench in the square opening, results in a reasonable length lever.perhaps fab up a long handle for the spin index and take it slow. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Or use the spin indexer but don't rotate it while cutting. Set the quip depth stop and peck away at it rotating a little bit and locking it down each time but with the cutter out of the work. Might also help in following the line as you can adjust position before reaching final depth.
Grigg | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I'm sittin' it out in the house tonight Grigg. It's situations like this that make me look seriously at new equipment that I've been wanting for the shop. Might just look into a small dividing head. There have been many times in the past that I could have used one but shelved the project for the lack of. Been wanting to cut some custom gears but haven't wanted to do them the hard way. Might be the right time to look into it.
dg
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Okey dokey Grigg. Took your suggestion and ran with it. http://www.pbase.com/dennygraham/image/162416099 A little wobbly but good enough for an oil groove. Thanks for the idea. dg
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Very nice! Glad it worked out,
Grigg | | | | | Joined: Aug 2001 Posts: 3,616 Moderator | | Moderator Joined: Aug 2001 Posts: 3,616 | Looks good Denny. Faster and cleaner than a dremel.
My Dad always said. "A good machinist is a little bit lazy, cause he will find an easier to do something and 90% of the time, it's faster and cheaper".
Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I don't claim to be a machinist Don, just been crankin' on handles when ever I had the chance since I was a toddler. More of a machine operator. But I do have to admit to being a little bit lazy, I usually look for the easy way out. Never made much sense to look for the hard way of doing something if there was an easy way.
Dang it though, I still want to put a dividing head in the cabinet, now I'm gonna have to look for another reason to get one. The bargain basement, spin indexer worked ok, but with a one to one turn ratio the spiral is nothing to brag about. Really hard to keep up with it cranking on the X-axis.
Some people may wonder what a machine tool discussion is doing on the Stovebolt forum, but....restoring a machine tool, i.e., a big old lathe in this case, will enable me to make those 1 3/4" and 1 7/8" tube bender dies for my tube bender so I can make my own custom exhaust bends for the trucks, so that's the "connection". Now what happened to that easy way bit??????
tanks guys, Denny G
| | | | | Joined: Aug 2001 Posts: 3,616 Moderator | | Moderator Joined: Aug 2001 Posts: 3,616 | Denny That quote can be used in about any type of craft/trade. Always find an easier way to do something.
