| | | Forums66 Topics128,126 Posts1,056,355 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That was a saying that an old buddy of mine used whenever we were lifting heavy STUFF. Ed's long gone now and I never even thought to ask where he got it from, we always knew what he meant by it. I'm just an old retired guy now a days, I never reached the status of tool & die maker, but I've been cranking handles on lathes and mills ever since I was a kid as my pop and big brother always had a mill and lathe in the basement shop. Also on the job over the past 50+ years I've drifted in and out of the machine shop when the need arose. In my home shop I've had my Logan 10" and round ram Bridgeport for about four decades. Now for about half that time, I've had this 1912 Lodge and Shipley 16" selective head waiting to put back in service. This is finally the winter and I'm putting the finishing touches on what it needed to get it running again. Problem is.....at 73 close to 74....I don't what to strain my milk lifting those big old three and four jaw chucks into place. My shop area is like stuffing 10lb. of crap into a 5lb. bag, in other words, it's pretty crowded and the Large & Shapley lathe is in a rather awkward spot to get the cherry picker maneuvered in. http://www.pbase.com/dennygraham/image/158511117/large I need to cover the length of the bed so I can pull the tail stock or load a heavy work piece into place. I'm planning on rigging up some kind of hoist over the lathe, probably with a Reese Winch or something similar. The wall behind the lathe isn't sturdy enough to hang a Jib from so I'm going to have to hang something from the 2x8 floor joist 8' above the bed. Oh....and the other thing is....it's gonna have to be something I can fab here in the shop and something inexpensive, remember now....I'm an old retired dude on a fixed income. Any ideas to get the juices flowin' and get me started at the drawing board???? Denny Graham Strained to the limit in Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Aug 2001 Posts: 3,600 Moderator | | Moderator Joined: Aug 2001 Posts: 3,600 | Nice shop and setup. How about using something like a sliding garage door system. Uni-strut attached to all the floor joists to spread the load out and rollers that would run it the uni-strut. 1/4 ton hoist attached to the rollers would be all you would need. I have seen this setup before for light loads and they worked good.
Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | Small I beam bolted across the joists to spread the load. Longer than the machine so you can drop things to the ground. Then find a trolley and hang your winch from it.
If you had more head room, I would say you could set up a rail system. Which you probably could still do if you set the rails along your joists, above the bottom of them, the width of the room. Attach some rollers to your I beam so the beam hangs and rolls on your rails. Then trolley for your winch. You'd have to get creative with the lighting, maybe attaching the fixtures out from the wall as opposed to hanging them. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Hang something like this from the ceiling. Mount your winch to it rather than a door. You can get the hardware from Home Depot.
| | | | | Joined: Aug 2001 Posts: 3,600 Moderator | | Moderator Joined: Aug 2001 Posts: 3,600 | 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Jan 2014 Posts: 3,689 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,689 | I know just enough about rigging and hoisting to know that it's no joke. Does anyone have some idea what sort of strength/ dimension of a wood beam would be needed for a chain hoist attaching point? For a beam that might see a max of 1000 lbs and spanning about 12 ft?
Here's my situation:
* Got a "garage/shop" (some call it a john deere room) and one end of my walkout basement. Concrete wall on one side, stud wall parallel separating the finished portion. Probably 12 ft wide or so with joists above crossing perpendicular. A "cherry picker" can and has been used in this area but takes up way too much room.
I don't want to use a joist for the beam, even if I doubled one, because I see some risk to the tile floor above. (Pulling down the sub floor above).
My thought would be to rest a beam across this area, in an existing joist cavity, but isolated from the joists. The very heaviest thing I would ever try to lift would be a stovebolt engine (600-700 lbs). Would also be very handy for lifting the front of the zero-turn lawnmower for under-deck maintenance (probably secured with jack stand after lifting).
Probably would get a manual 1-ton hoist as overkill. Just need to spec the beam and figure out attaching point (eyebolt vs chain or cable looped over the beam).
1951 3100
| | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | Denny you might check out McMaster-Carr in there pulling and lifting sect.,#3626t11 and #3310t212. root | | | | | Joined: Mar 2010 Posts: 10,281 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,281 | Strained my danged milk today! I feel like I'm laying on bag of baseballs, and keep making ole man noises. I thought we are supposed to get smarter as we get older...
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | So...that's what I did. Good for 300lbs which is more than I'll ever load/unload to/from the lathe: http://www.pbase.com/dennygraham/image/162516819 tks for the ideas guys. dg
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | That's a very nice setup Denny! I was thinking of just a single beam. Your bridge setup is so much better.
Grigg | | | | | Joined: Aug 2001 Posts: 3,600 Moderator | | Moderator Joined: Aug 2001 Posts: 3,600 | Looks good Denny! That should do you well. Edit: Like Grigg said, I visioned a single rail.You took a general idea and improved it. The only things that may get in your way are the lights. Most of the shops I have worked in had the 4 foot lights hanging from threaded 3/4 water pipe attached to the lathe headstock. Vertical, a 90 elbow and then a horizontal. The elbow was not tightened and you could swing the light out of your way to load/unload the machine. Just food for thought.
Don
1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Put hooks at 90° to the far end. I just swing the end over the bed over to the other hook and then I can use the whole length of the rails. I won't be using the crane that often, only to change chucks, which is pretty seldom, and maybe to lift something heavy into the chuck, like a crank. dg
| | | | | Joined: Aug 2001 Posts: 3,600 Moderator | | Moderator Joined: Aug 2001 Posts: 3,600 | Denny I thought you would have it planned out some how.
But, and here is the but, about changing chucks. Once you get used to a four jaw chuck, you will never go back to a three jaw.
Kind of like water skiing, once you learn how to ski on only one ski, you never go back to skiing on two skis.
That is a nice system that you have built and I can be jealous! Do you need any indicators, mags or mics? My machining days are probably over, and I still have most of my tools.
Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Not really Don, but thanks. Been collecting for half a century myself. I'd love to have a good digital height gauge but I'll have to be satisfied with my 12" vernier height gauge, just a bit more work now that those lines have gotten so small.
dg
| | | | | Joined: May 2015 Posts: 11,072 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,072 | That's awesome. I've spec'd out some much larger bridge cranes (5-10 ton), but that one is just cool.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Aug 2001 Posts: 3,600 Moderator | | Moderator Joined: Aug 2001 Posts: 3,600 | Vernier scale, not too many machinist now a day even know what that is. Ran an old 6" hoz. gantry G&L mill years ago, that you rode on a platform. Vernier scale on the hoz. was six to ten feet below with a light on it. You had to look thru a microscope type of lens to focus in and read it from the platform, or climb down close and read it. Edit: Floor type Hoz mill. It was also equipped with a DRO, but always like to check the vernier to make sure on the big stuff. http://fultoniron.net/Don
1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Had one like that at Fermilab in the main machine shop, called it the "Queen". We had a lot of old surplus Navy machine tools when I started there in the 70's. A particle accelerator is a huge machine to find the smallest of things and it took a lot of big machine tools to make the machine. Cut my teeth on vernier instruments. I handed my daughter my Post slide rule once and she thought it was some kine of musical instrument. dg
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Denny, I'm a little late to the party, but after looking at your pictures I have a concern. It doesn't look like there are any bolts going through the joist, so I'm assuming you just lagged the strut to the bottom of the joist. If you attempt to pick a load up from one of the corners you will have the entire load hanging from just one screw which could pull out of the joist. Here's the way I'd support the system (see link), at least on the corners. I hope you already have something and I just don't see it! Would hate to hear you dropped some heavy item and got hurt. http://s160.photobucket.com/user/st...5254_zpsm2tivmo0.jpg.html?sort=3&o=0Mike B  | | | | | Joined: Sep 2015 Posts: 54 'Bolter | | 'Bolter Joined: Sep 2015 Posts: 54 |
