7 members (Gdads51, Otto Skorzeny, TexasA&M48Truck, 5cameo8, TUTS 59, Youngin' Tut 59, Gray_Ghost),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,116 Posts1,056,599 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 101 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 101 | I am going to try this question over here now, they are too busy to help me over in the parlor.
What are the different ways and products to clean up the stainless steel trim?
Mark
1946 1/2 ton - 1962 "261" 1953 1/2 ton 5-window - "235" 1955 1/2 ton - 55 "265" Corvette motor 1959 1/2 ton Fleetside - "283"
| | | | | Joined: May 2002 Posts: 8 Member | | Member Joined: May 2002 Posts: 8 | I've used several things. Turtle wax makes a chrome cleaner that works pretty well. depending on how nasty it is. I've also used degreaser to remove the crud then used wax or mother's mag wheel cleaner buffed out with my dremel or buffing wheel | | | | | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | I cleaned up a bunch of trim on my truck using a cloth wheel on an electric motor and some red rouge or polishing compound.
I know the Eastwood Company sells lots of products for cleaning stainless.
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
| | | | | Joined: Jun 2000 Posts: 30 Member | | Member Joined: Jun 2000 Posts: 30 | best thing I found was metal restorer made by Meguires. Get a cloth wheel for your bench grinder,..put a dab or three on your fingers...rub it around the wheel..rub it into the wheel...turn on the grinder and polish away. The restorer works by hand too but I found the wheel faster and brighter. | | | | | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | Mark,
Look back at the posting in the lounge for sources of Wenol products. You might also find them available at major auto events and swap meets.
Have had good results on some badly corroded stainless (guy was cleaning parts with acid and drift got to the newly installed stainless on his '57 Chevy). Good luck finding the product. | | |
