6 members (Nick in Manitou, frogfarmer, Southerntruck, 3B, cmayna, Gdads51), 116 guests, and 3 robots.
Topics128,089
Posts1,056,433
Members48,443
#1144957 01/16/2016 2:51 PM
Hi hipop. Folks I'm trying to get all the info on ifs swaps. I'm building a 49 6400 with a 7.3 hi perf. Diesel in it. I'm currently working on getting a p-30 ifs under the front by narrowing it to fit my frame. It will be a touch wider on wheel width which I'm fine with. Just like to hear more about others mods for ifs.
29 Ford
http://s1078.photobucket.com/user/c...4-BF50-713F5EDE5632_zps8zoj9vfq.jpg.html
31 Ford
55 panel
95 4 door power stroke
49 chevy 2 ton
47 2 ton grain bed w/ hoist.
Many trucks waiting
Crusing in the Passing Lane
It would be great if the frame were extended a slight amount to fit the IFS suspension, if the tires do not stick out the fenders. Does a P-30 or 3500 solid axle fit as-is?
Ed
Also consider this disc swap keeping old axle beam. Might allow more room for engine than IFS does.
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1135069/Disc_brakes_for__3/4,_1,_1.5,_.html#Post1135069
•1952 Chevrolet 3800 pickup
---All pictures---
The tires will be a little wider than 2 inches each side than stock . Similar look as sherocoms 46 after choping cross member. If there a little too wide I'll widen fender. This is my direction and I'm on a quest! Maybe?? This truck will produce over 500 horse power and I want an ifs to steer it. So I'm trying to gain knowledge. I believe talk it think measure it and repeat it unti positive
29 Ford
31 Ford
55 panel
49 chevy 2 ton
Many trucks waiting
Worked on truck yesterday 3 degrees in shop when I started. Got final measurements and cut 4.75 inches out of the middle of the crossmember. I've asked so many questions on this from reading Sherocom 46 post on his truck he had stated that he only removed less than 2 inches I believe 1.25. That confused me since his 46 is a narrower frame by approx. an inch.my 49 required almost 5. That leaving me 2 inches wider wheel width depending on wheel I use.
29 Ford
31 Ford
55 panel
49 chevy 2 ton
Many trucks waiting
