| | | Forums66 Topics128,078 Posts1,056,036 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2015 Posts: 273 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 273 | I'll say it again...sweet truck.
1953 3800 Dually Flatbed
| | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | sweet looking truck! You start by taking off the inner door and window handles, (armrest if it has one) and then the inner door panel. Once that is off, you can see the window mechanism, you will need to take the wing window assy loose as it is the front track for the window ti slide up and down in, that should get you well on the way to getting the glass out! | | |
